01-12-2022 10:35 AM (Last edited 01-12-2022 11:00 AM ) in
TV & Audio
Disposable batteries are not the best for the environment. Unlike other remotes, your 2021 Samsung QLED TV’s remote doesn’t need them. It has a solar panel instead that you can use to charge your remote – whether you’re indoors or outdoors. The remote also comes equipped with several smart features such as a built-in microphone for use with a voice assistant.
The Samsung SolarCell Remote can easily and economically be used – anytime, anywhere. Now, use your Smart TV even smarter!
Please Note: The information on this page is for Australian products only. Models, sequences or settings will vary depending on location and/or where the product had been purchased. To be redirected to your local support page please click here.
What are the benefits of a solar remote
A solar cell on the back of the remote absorbs sunlight or the light in your home to charge the internal battery. A single, fully charged battery can last up to two years, making it an economical alternative to disposable batteries. It is estimated that over the next 7 years, 99 million alkaline batteries will be used. The solar remote is well-suited for today’s eco-friendly era, and can work to reduce a part of that staggering number.
Charging the remote
If the battery is low, your remote control may not function properly, or may respond slowly. Use a USB port for faster charging. When the remote is not in use, remember to expose it to light. This will extend the remote`s operating time.
Option 1: Through the solar panel
While your remote can be charged outside in the sun, it can also be charged with your indoor lights. Simply set the remote down with the solar panel facing up to charge the remote. You can do this in your living room while your lights are switched on or you can place it near a window to soak in natural sunlight.
Option 2: With a USB-C cable
If you need to charge our remote right away, you can use a USB-C charging cable. Plug one end of the cable into the remote’s charging port and the other end into a port on the TV or into a Samsung wall charger adaptor.
Note:
- For faster charging and maximum usage time, refrain from using the remote while it is charging.
- USB-C cable and charger are not included.
Smart Remote Features and Functions
Check Remote Battery
Troubleshooting
Experiencing troubles with your TV remote not working? Follow the steps below for further information
Note: If your TV will not turn on, please follow our guide How to troubleshoot the Samsung TV that will not turn on
If you continue to experience troubles with your remote or lost/damaged it, please contact us on 1300 362 603 or reach out to us via Chat Support
If you require further assistance, please consult the user manual from our Manuals & Downloads page or contact our Samsung Care Australia experts on 1300 362 603 (Toll Free in Australia). You can also contact our Chat Support team or reach us through Samsung Members Community.
01-12-2022 07:50 PM in
TV & Audio- Mark as New
01-28-2023 03:48 PM in
TV & Audiohow long should it take in sunlight to fully charge up from 10%
