09-10-2021 09:01 PM in
Wearables- Mark as New
09-13-2021 03:47 PM in
WearablesHi @Samsungsupporter, sorry to hear that you're experiencing this issue with you Active Watch 2. I would recommend first checking that your Watch is up to date with software. To do this please go to Galaxy Wearables app > Watch software update on your connected device.
I would also suggest turning on power saving mode- https://www.samsung.com/au/support/mobile-devices/enable-powersaving-mode-on-samsung-watch/
If you believe there may be a fault with your device's battery, I would then suggest you send an error report via the Wearables app. To do this, open Galaxy Wearables app> open onto the wearable with the issue you’re experiencing > ☰ > Contact us > Error reports.
Let us know how you go!
07-21-2022 09:37 PM in
WearablesHi Samsung. We are facing same issue that has been mentioned about drain battery. I have given gift this watch to my wife and battery drain out in afternoon even if full charge in morning. We have tried all things you have mentioned. I have reset tye watch as well. I am getting frustrated after spending lots of money on watch and it didn't work. Please advise.
Thanks
07-22-2022 02:26 PM in
WearablesHi there, thanks for reaching out. As you've mentioned trying other troubleshooting tips, my next suggestion would be to send an error report for his to be looked at by our research and development team.
To send an error report for a wearable, follow these steps:
- Go to Galaxy Wearables app > click on the device desired on the side menu
- In the side menu, tap Contact us > Error reports (in the Get help section)
- Fill in details and the frequency of the issue that you have with the wearable.
- Click send.
10-17-2021 10:03 AM in
WearablesI have a gear s2 and over the last month I have charged it full and within 4 hrs it totally flat. I have turned off all not essential apps and wi fi but still draining.
10-18-2021 12:50 PM in
WearablesHi there, please send through an error report via the Galaxy Wearable app.
- Click send.
