03-04-2025 07:44 AM in
WearablesSolved! Go to Solution.
03-04-2025 05:01 PM (Last edited 03-04-2025 05:29 PM ) in
WearablesI also had something similar. I'd be playing a song while browsing internet, browsing YouTube and if I have too many apps opened, the music would stop.
I believe it's a RAM issue. The phones only have 4gb RAM which isn't quite enough to have too many apps opened at once.
I've since upgraded to an A35 and it's been great.
I believe the A26 and upwards will have 6gb of RAM, so I'd choose one of them if you're looking to upgrade!
03-04-2025 08:22 AM (Last edited 03-04-2025 08:29 AM ) in
WearablesIs your wearable app up to date as well?
(I work in IT, and most of the time, the problems occur just because they haven't been updated or restarted in a long time)
If that doesn't work, try:
Open wearable app>Buds 2>earbuds settings>about earbuds, check if the earbuds themselves are up to date as well.
If this still happens, we can use a more advanced approach
03-04-2025 04:03 PM in
Wearables- Mark as New
03-04-2025 11:30 AM in
WearablesOr do you have to press play again in the music app?
03-04-2025 03:20 PM in
03-04-2025 06:21 PM in
WearablesSettings > About Phone > Software Information > Build Number
Tap 5 plus times to access development mode.
Frequently, it should be 1.6 or less, depending on the age of buds / headphones.
03-05-2025 06:05 AM in
03-05-2025 10:39 AM in
WearablesAlso, it has a Clean widget.
03-05-2025 03:20 PM in
Wearables
