How to use phone mic while using buds 2 pro when in call
(Topic created on: 12-15-2023 08:46 AM)
Zeno08
Wearables
As the title states. I wonder If I can use my fold 5 microphone instead of buds 2 pro mic when in calls
3 REPLIES 3
Ceejern
Wearables
Just to be clear, you still want to hear the other end with your buds, but your mic input should come from the phone mic? If that's the case then I don't think there's an option for that.
If you want take the phone call with the phone's mic and hear them through the phone's speaker then it is possible.
Just go to notification panel, long press on bluetooth, select details, and then press the gear icon next to the name of your galaxy buds, and toggle off the switch for calls.
Zeno08
Wearables
Thanks for the reply! Looks like I really can't use my phone's microphone for input and simultaneously use my earbuds for audio output on calls.
Ceejern
Wearables
Yeah, if that would be possible I'd use that too. My galaxy buds 2 sound terrible in calls. The other end always tell me I sound muffled.
