Yorkieip
11-14-2022 06:28 PM in
Wearables
Hi all, can't seem to connect my SM-R905F to a mobile network. Have been through extensive trouble shooting with the carrier and Samsung and keep getting the same error codes, 3001 & 4001. Can anyone help?
Solved! Go to Solution.
NatalieLC
11-15-2022 08:58 AM in
Wearables
Same. If you have a Telstra One Number service already active, ask them to cancel it. Then wait 24 hours exactly and try again. I've just done this and now it's working :)
6 REPLIES 6
NatalieLC
11-14-2022 07:20 PM in
Wearables
My partner and myself are having the exact same issue. Apparently it's a worldwide problem which they're trying to fix
Yorkieip
11-14-2022 07:32 PM in
Wearables
Oh ok, thanks for the heads up! 😀
NatalieLC
11-15-2022 08:45 AM in
Wearables
What service provider are you with?
Yorkieip
11-15-2022 08:49 AM in
Wearables
Telstra, you?
NatalieLC
Wearables
Yorkieip
11-15-2022 09:10 AM in
Wearables
Thank you for your advice. I just tried it again and it worked! It's been about 24hrs since I last tried it so a bit of patience did the trick. 😉
