Resolved! Solved
Samsung Galaxy Watch 4 not charging on Samsung QI wireless fast charger
(Topic created on: 02-15-2023 05:19 PM)
Ninny3030
Wearables
Hi! I have lost my watch charger so I have tried to charge it using my wireless charger, it does not charge and just shows a flashing blue light on the charging stand. It charges my phone perfectly fine. Also I cannot powershare because I only have an S8. Any help appreciated.
Wearables
It won't work because the charging coil in the watch 4 is smaller than those 3rd party wireless charger, so it will not charge.
You have to get a smaller wireless charger. I use the charging duo from Samsung and that works fine.
2 REPLIES 2
IBEARI
Wearables
Do you have a metal band on it?
Wearables
