Battery Drain
(Topic created on: 08-03-2025 08:32 AM)
Froglette
Discussion
I've shown one or two steps to help reduce battery drain. But did you know most app don't really need to run in the background or use background data usage. For most apps you can turn these off in setting.
To add to that, you can even put most apps into deep sleep. They still open and operate normal when you do so. The only downside to this, is updates for those app may not appear when checking for updates. But when you do open the app and use it you can then check for updates or will be notified if you have update notifications switched on.
Just simple things that help make your battery go the extra miles. Not many of us use every app every day. So why have it draining battery and data unnecessarily? Everything i leave an app i usually force stop and clear cache as well. (Note: i did say Usually not always). 😆
Just one last thing, run your screen in dark mode. Saves battery too.
10 REPLIES 10
alejcho
Discussion
Great tips 🙏 I also recommend setting Extra dim (maybe also on a routine for automation) for additional battery savings1754174795674.jpg
Froglette
Discussion
Well done. Nice tips
Froglette
Discussion
imagroova2
Discussion
Geat info & advice! Thanx for sharing 🙏
Protonumus
Discussion
Moderate Use (Late-Model Devices):
For devices that maintain battery life throughout the day, keep Power Saving mode off to ensure optimal performance.
High Use (Power Users):
Activate Power Saving mode to extend battery life a few hours or more, during busines hours.
Maximum Power Saving:
Enable maximum power-saving settings to gain an additional 24 hours or more of battery life.
Note: Disable Power Saving mode at home for improved performance.XdlXgaoo8T.pnguP45fiCgNf.png
Froglette
Discussion
This is true. I get just over 3 days from one charge of my phone.
Discussion
Nice, very useful post 👏
Froglette
Discussion
Thankyou
Discussion
Totally agreed, I do this to save battery too. Great post mate!
