Resolved! Solved
Smart led view case
(Topic created on: 07-03-2022 10:49 PM)
becaree
Discussion
Smart led view case stopped working after update and i cant find the app on my phone anywhere. Have taken phone out of case to try reset it but having no luck any ideas on how to fix this. My phones an s22 ultra.
becaree
Discussion
Thank you i left the phone out of the case over night and put it back in and it worked
5 REPLIES 5
Discussion
@becaree can you check your phone and see if NFC is turned on, this can cause the issue you're experiencing.
I would also recommend sending an error report via the Samsung Members app.
Samsung Members app > Get help > Error reports > Application > Describe issue and frequency > Tick ‘Send system log data’ > ‘Send’ in top right.
becaree
Discussion
Discussion
That's great to hear.
If it does occur again, please do send an error report, as this helps Samsung find and correct issues.
SamsungLaura
Discussion
Thank for letting us know the solution @becaree, do let us know if this occurs again.
becaree
Discussion
It has occurred again
