How much to replace battery of Note 20 Ultra?
(Topic created on: 11-04-2023 06:07 PM)
SuperLovedandBlessed
Galaxy Note
Anyone here had their battery replaced? What's your experience?
9 REPLIES 9
KCL20
Galaxy Note
I heard its 2k to 3k plus dont forget the tape to bind it back.
Galaxy Note
So expensive.. 😞 thanks for the reply. Have a nice evening
KCL20
Galaxy Note
Yes even the green line issue cost a lot to change the LCD. I hope samsung could fix that issue to all samsung unit.
Galaxy Note
So expensive..😞 thanks for the reply. Have a nice evening
Galaxy Note
3600 nung nagpapalit ako sa for my Note20U
Galaxy Note
Was it worth it? Did the new battery last longer? Did you have to leave your phone or did you just wait for a few hours?
Galaxy Note
I had to leave my phone since may iba pa akong issues na pinagawa. I had to wait for 2 weeks again para mag adapt ulit yung battery to my usage pattern. So far so good after that.
jmndbnstlk
Galaxy Note
Saan po kayo nagpapalit? What about the screen? May idea po kayo?
fname
Galaxy Note
Mine was 12k I think. Last year. It took more than 1 month kasi nung binalik sakin, yung replaced LCD may defect pa rin.
