Resolved! Solved
note 10+ charging problem
(Topic created on: 09-11-2020 10:32 PM)
Santoshlove20
Galaxy Note
i face charging or earphone peoblem after i drop my mobile in water for few(1 or 2 sec) only
its show your usb port are not a dry after 2 hour also same problem
Earlch
Galaxy Note
Better put inside the rice to absorbed all the liquid first. Might not reach for an hour can be charged already.
7 REPLIES 7
haematocrit
Galaxy Note
A couple of hours won't do. Try leaving your phone in front of the fan (don't let it blow directly in to the charging port!). Give it at least 1 day.
Earlch
Galaxy Note
Sy3ney
Expert Level 3
Galaxy Note
You may try to use hair dryer with the phone port facing down.
scinex
Galaxy Note
The phone is detecting there's moisture at the charging port, so I guess you need to dry it up. Fastest solution is what our friend Sy3ney suggested, by using a hair dryer, but don't set it at highest heat. It might then contribute to another problem.😉
Santoshlove20
Galaxy Note
thanks all now phone is working well i fllow (Earlch) step
Minaamina
Galaxy Note
remember to tick the suggestion given as solution if it worked..
Earlch
Galaxy Note
Thanks for the Solution Tagged 👍 👌
I do have this experience for the Galaxy not charging after detected some moisture inside. Since I don't had an hair dryer (fastest Solution), rice is the other option. Anyway it's a good features to let us know it's still not dry up yet for continue charging the battery. 😁
