Note10+ battery drain
(Topic created on: 04-06-2021 02:14 PM)
Kombatsd
Galaxy Note
I just want my Note 10+ battery changed while still under warranty but the authorised repairer flashed my phone and asked me to try it again to see if the battery is better. Didn't work. Went back and they said they'll have to reflash my phone and won't change a new battery if they deem the battery is alright! As a daily user of the phone, I would know if my battery is discharging quicker than before. You realise how difficult it is to get banking apps back onto the phone? If it's under warranty, Samsung should just do a straight swap.
9 REPLIES 9
SamsungJon
Galaxy Note
Hi Kombatsd, could you please send us any reference numbers and your contact details through our email and I'll take a look at this for you.
Kombatsd
Galaxy Note
Hi. What reference numbers are you referring to?
SamsungJon
Galaxy Note
Hi, you should have received a reference number when your Note10+ was assessed. If you're not sure about that, you can send us your serial number instead :)
Kombatsd
Galaxy Note
Hi. It wasn't assessed because I didn't want my phone to be reflash again and then they decide they won't replace the battery.
Kombatsd
Galaxy Note
Just sent an email to you. Thanks
Riksta
Galaxy Note
Yes I reckon that your totally right mate, I had an argument with Samsung because my s20fe kept over heating and closing my apps, they didnt wanna do anything. Crap customer service hey
Kombatsd
Galaxy Note
Absolutely mate. Thinking of changing over to the Google pixel when the new one comes out.
Riksta
Galaxy Note
Really mate, I dunno maybe just update your phone to the 20
Kombatsd
Galaxy Note
Yeah, I'll just wait and see what comes next. Maybe the Fold 3 😁
