Note10+ LED Cover
(Topic created on: 08-11-2021 02:58 PM)
Chuck58
Galaxy Note
My LED Cover stop working in my note 10 + I've tried everything can some one help me please?
1 REPLY 1
SamsungJon
Galaxy Note
Hi @Chuck58, here's a few troubleshooting steps you could check (if you have not already done them):
- Check if your device is registering your accessory. You can do by checking if there is a LED icon editor entry in Settings> Advanced features> Accessories.  If you cannot see 'LED  icon editor entry', please remove your case and then put it on again to see if it registers.
- Go to Settings> Applications> next to the 'Your apps' title, toggle on select show system apps> find LED Cover > Storage > Clear cache and clear data.
If your LED Cover not working after these steps, I would recommend that you send that you send an Error Report through our Samsung Members app. For the guide, please see here: https://r1.community.samsung.com/t5/tips-tricks/sending-error-reports/td-p/9617204
Let us know how you go!
