Android Auto Connection Issue
(Topic created on: 07-21-2025 11:28 AM)
SteveMac
My new S25 Ultra won't connect via cable to my car even though it connects to other cars and other phones connect to my car by the same cable. Samsung is struggling to fix it and I have tried all the software adjustment fixes suggested elsewhere including: reset phone, reset car head unit, uninstall/reinstall Android Auto, update everything, turnnoff autoblocker, clear Android Auto cache and data, clear usb data, use developer options to check that default usb setting is not just charging, etc. Looking for suggestions I haven't tried. Samsung has my phone and say it is operating according to manufacturers specifications. Samsung Support were able to fix it once by connecting remotely and changing something that users can't but after connecting to a hire car I can't now connect to my car even after redoing all the software adjustments including forgetting other car and Samsung Support can't replicate. Any suggestions welcome.
19 REPLIES 19
SteveMac
Thanks. That is who I emailed. I emailed again and they have responded with a repetition of all the previous advice that didn't work. Samsung tried to fob me off this morning. It is escalating to their Voice of Customer Team.
LindsayH
Having same problem with my Samsung A15 5G. Only car it wont run Android Auto is my 2020 Holden Colorado.
SteveMac
Samsung have agreed to replace my S25 with another new one.
SteveMac
Received replacement S25. Same problem.
SteveMac
One month later and Damsung and Google still can't fix the connection issue. Spent a fortune on different cables even tried USB Dongle with no improvement. I can't connect my S25 to Android Auto in my car.
SteveMac
Samsung! No pun intended above.
Troubadour
Did you fix it, if not have you tried one of the suggestions, turning VPN off? VPNs also have settings where you can exclude certain urls from stadard VPN settings.
SteveMac
I have tried all of the suggestions without success. Samsung, Google and Mazda all have had multiple log files for months with no positive feedback (actually no feedback at all other than acknowledging my follow up queries for feedback saying we are looking at it).
SteveMac
Response from Google after many weeks waiting and another follow up request from me:
Hello
Thank you for reaching out to us regarding the issue you reported. We appreciate your patience as our team continues looking into it.
We want to assure you that your concern is a priority for us. Our technical team is currently conducting a thorough investigation into the matter you described. Due to the complexity of the issue, the investigation is taking a bit longer than anticipated.
We will continue to monitor the progress closely and will provide you with another update as soon as we have more concrete information. No further action is required from your end at this moment.
Your understanding and cooperation is much appreciated.
SteveMac
And from Samsung:
Good afternoon Stephen,
I'm sorry to hear this issue continues to occur.
The log file attached to a previous error report is currently with our research and development team to be analysed. As this has been with our R&D team for longer than expected, I have contacted the engineer and requested for your case to be reviewed as a priority. Once they have concluded the analysis of the log files, we will be in touch again to let you know the outcome.
We appreciate your patience while we investigate this issue.
Kind Regards, Ethan
Samsung Members Team
