Fast Charging Problems with S10
(Topic created on: 07-20-2024 08:26 PM)
Violator540
I need help; this has been bothering me recently. A couple of days ago, my phone was still fast charging, but yesterday it suddenly stopped fast charging and only says "cable charging." However, it still charges in about 2 and a half hours, similar to fast charging. If it were really slow charging, it would take longer than 2 hours. I've changed the cable and used my power bank, which supports fast charging, but the issue persists.
I've been thinking, could a bad battery cause this? Recently, my phone has been running warm even when I'm not using it. My phone has also warned me 2-3 times that I need to change the battery, but I ignored it until now when it's showing these symptoms. I can't afford to replace my phone or have a motherboard repair right now. Can anyone assure me that this is a battery issue before I bring it to a repair shop to get it fixed? I'd appreciate any answers.Screenshot_20240721_111553_Samsung Members.jpg
7 REPLIES 7
butete
+1 battery
KennethJAO
Beginner Level 5
+1 battery problem
It does seem like a battery problem. When I got my Note20U5G's battery replaced, it set me back for 3600 at the Samsung store in Megamall.
SagaOtaku
Battery replacement cost a lot like the price of Galaxy A35 5g or A55 5g
TeamGalaxyElla
Hi Violator540,
You can use the Samsung Members app to run a diagnostic check on your phone. It might help identify if the battery or another component is causing the issue. If the app suggests a battery problem or if you’re still having issues, visiting an authorized service center near you would be the next step.
Violator540
Everything passed except for the battery though, I just wanted to make sure if a bad battery can cause this issue.
Teegs
Kaya mas ok sana maibalik un dati na pwede palitan ang battery pag nag lowbatt na at meron ka spare para di hassle. Mas magastos pati ngaun at sobra mamahal ng bagong smartphones at mga accessoeies na legit
