Resolved! Solved
Finger print sensor not working, why so I do not know.
(Topic created on: 07-13-2022 10:04 PM)
Sherro
I started having this problem a fortnight or so ago
Now the sensor is useless
I bought an Samsung approved screen protector
Should I delete the fingerprint and make a new one, or is the is sensor on the blink and need to be replaced.
Any help o direction very much appreciated
Terry Sheridan
2 Solutions
Hi @Sherro when using a screen protector, you should redo your fingerprints.
Also, you can adjust the touch sensitivity as well.
To do this, go to Settings->Display->Touch Sensitivity and turn it on.
Hope this is helpful.
Sherro
Dear Dolgogi Thankyou very much for your help.
Hi ow lucky we are to be able to come here looking for help or of advice and
Í managed to get the screen protector off, it wa far be easier than I anticipated, all up timewise 5 seconds.
After adding a new finger print all been is working well.
Not sure whether or not to buy another screen protector, perhaps a Samsung protector well be operated with no problems.
Anyway thank you once again Dolgogi
8 REPLIES 8
SamsungLaura
Thanks @Dolgogi!
👍 no problems 😊
Sherro
G'day Dolgogi
Many thanks for your reply
Sorry for the delay in responding, circumstance unfortunately.
My problem is unresolved, I was finally able to get to sorting this problem out.
After I deleted my finger print My sensor won't accept my fingerprint.
I don't have a Samsung screen cover, but the one got was my an acceptable cover for a Samsung phone.
It appears that the cover is the culprit in my fingerprint issue.
How do people remove the screen cover ?
I can only see further problem
Do you have my any suggestions?
Hoping you might have a suggestion or two.
Thanking you
Terry
Did you try turning on screen sensitivity?
Did you get a film style or glass?
Either way, you should be able to peel if off, though go slow and use caution if it's a glass protector.
Sherro
Thankyou Dolgogi for your reply
Yes that is turned on so it seems that might not be the issue.
I am not sure what film it is but it is clear as it can be
I just need to be know I can get the screen protector off
Sherro
You're most welcome, this is what the community is for 😊
The Samsung protectors will work fine, and since they're sold by Samsung, you should have peace of mind.
Try and buy from a Samsung store if possible and let them fit it.
