Help
(Topic created on: 12-26-2021 02:50 PM)
LynneB
I have new Samsung A52s somehow I have managed to turn off notifications (the numbers that show up on the icons) so you know you have a message etc
14 REPLIES 14
Go into Settings, and scroll down and select Home Screen.
Then look for App icon badges.
LynneB
Mine shows the same
LynneB
Is there anything else that might work?
Is this issue affecting all apps, or just the Messages app?
LynneB
Everything that used to show numbers dont anymore. Facebook messages Instagram etc
You haven't turned on Do not disturb mode, have you?
Do you get sound notifications?
LynneB
I had a look it is not blue in the drop down
LynneB
No just sent myself an email and message no sounds
Last 2 things I can suggest is:
Go back into Settings/Home Screen and tap on App icon badges.
Where is says on, try toggling it off, then back on.
Failing that, I would suggest sending an error report via the Members App.
