Problem in S20+ vertical line
(Topic created on: 05-19-2022 05:06 PM)
Cathiecath
Note! Updates.
So after what happend the same day i called the customer service and they advice me to visit the service center for more checking, on the center they explain what will do (heads up) so I agree and sign the docs after a week they said that my phone issues will be covered so they fixed everything. After more than a week got my phone back.. thank you..
Hi everyone using s20+ model just want to ask if you encounter problem in your mobile screen?  ( green vertical line )I already called the samsung customer service  but still wanted to hear feedbacks from a user of this model also. Thanks.🙂😔 it happend yesterday. I didnt drop it or anything it doesnt have scratch or cracks.
11 REPLIES 11
butete
may s20u will be 1 year this aug from screen replacement so far aok
Cathiecath
Does it charge free?
butete
much better get in touch with customer service
reggie1725
Hi! I had vertical pink line on my screeb after the software update. I brought my unit to the service center and replaced it for free so long as its a week or 2 after the update.
Cathiecath
I appreciate your response. Thanks for the info.
wjern
I see the same issue today.
Please update us what feedback u receive from service center
is your phone still under warrenty?
Cathiecath
My phone was under warranty as i check on their finding. They will check your phone so you need to leave it to them for a days for validation phone should not have dents, cracks or water leaks or any thing cause of mishandling. Better to visit the service center as soon as possible.
Justine1218
I have the same issue may kailangn po ba bayaran sa service center. Like diagnostic fee. Out of warranty na kc phone ko. I'm using it for more than 2 years.
TeamGalaxyRene
Hi Cathiecath,
Hope you're concern is resolved. Stay safe.
Be sure to click " ✓ Accept as Solution" when you find an answer that works for you.
