Resolved! Solved
Samsung's high usage of system storage
(Topic created on: 02-12-2023 07:33 PM)
haziqmahadzir
My S21FE storage is almost full with 90.79GB of system storage, what?
Resolved!
36 REPLIES 36
GunasamssYT
Awesome. Glad to help you 😃 👍
Kashoo
Beginner Level 3
 i have same issue but The "i" button is not showing here. Plz help
SIMIKUTTY
How did u done the system storage clearing? Can u pls guide. Am facing same issue and my phone is full
harvey_lover7
 mine looks like this. and I always clear my caches what can I do?
GunasamssYT
I'm really not sure on what's the issue there 🤔
harvey_lover7
so there's no way I can fix it?
GunasamssYT
You can try searching it on YouTube or Google there might be some solution.
alexandra127
How to search it
GunasamssYT
Go to my files, then scroll down until you find analyse storage.
richardmai2012
I have this same issue where it shows about 92.83GB for APPS and 26.53 for SYSTEM.  I've CLEARED cached and deleted a dozen apps and CLEARED Data for MANY apps, but it still shows what seem to be impossible.  Started having this issue ever since Samsung kept pushing for us to UPDATE the software.  I don't understand how I only have like 5 apps (FB, Starbucks, CVS, Ralphs, Albertsons) on my phone and it still shows 93.83GB for APPS.  Please help if you can.
