Touch Response and Battery Issue
(Topic created on: 10-26-2022 05:44 AM)
Athena_
Hi everyone. I'm currently having a problem with my phone (Samsung S21 FE). Whenever I'm charging and try to use my phone there seems to be a touch response problem. I'm not sure why. But when I unplug it, it returns back to normal. In terms of the battery, I'm not sure if its already like that but it usually drains 5% even though I'm not using it. Can someone help me on this?
7 REPLIES 7
butete
have you wiped cache partition
Athena_
Yep. I think I did almost everything just to resolve the issue but it is still the same
butete
set the phonecin safe mode and tedt?
Athena_
Yep. It worked but suddenly its happening again
butete
then theres an app thats triggers this
Athena_
how would i know what app that triggers them?
butete
its going thru isolation, you can start for uninstalling the recent application you loaded
