LED Notification light S23 Ultra
(Topic created on: 02-26-2023 12:10 PM)
MrBBear
If there is something I do miss, that's the LED Notification light which I had on my Samsung Galaxy Note 9, think this might of been the last of the Samsung phones that had it. Sadly my new S23 Ultra doesn't. Any ideas or suggestions. Thanks.
21 Comments
Anu13
I think there are some third party applications which allows you to enable LED lights around the front camera.
TeeeDawg
Same situation here, I jumped from a Note 9 to the S23 Ultra and I'm missing the LED notification light.
Most people seem to be using an app called AODnotify.
If only Samsung allows further configuration of their selfish camera lighting function.
www.samsung.com/us/support/answer/ANS00084922/
Try searching the EDGE LIGHTNING STYLE on the SETTINGS. It'll will lead you to the LED notification for s23U. 😉
Rapture21
We need the light indicator back. I don't hold my phone in my hand all the time and I am not by it. So, how would I know I had a missed text or call without picking it up and opening it 🤔. This was a big mistake on Samsung part. Us old folks are not like the younger generation. I don't need my phone in my hand 24/7.
Members_CNO9rFR
Beginner Level 4
Led colored light notifications  was such a handy function, can't believe they took it off. Is there a way they can bring it back in an update. I'm using AOD notify  and not that happy with it.
Vviv
As far as I can tell, that only works when you're playing games or streaming something full screen. Not when your phone is locked.
If AOD is turned on, it should light up when the screen is locked.
AdonisBiju
Holey Light is a good app which adds a ring around the camera hole to act as a notification light. It is an open-source app, so you don't have to worry about any privacy concerns.
MrBBear
So has the camera got a ring notification light around it, and can it change or have different colours. What's the actual purpose of this light around the camera front facing camera lens. I might try AOD Notify.
