Moisture problem
(Topic created on: 02-20-2025 02:29 PM)
Jangolde
does anyone experience moisture detection problem? almost 2days na ayaw ma charge ng s24ultra dahil sa moisture detection, ive tried all the steps that shows sa customer support.
9 Comments
PUFFY_AmiYumi
Remove the unusual particles inserted in the charging port using a mini brush.
Jnoitab
Try to restart first your phone, then clean your charging port both phone and charger.
Jnoitab
Last is, go to factory reset settings and clean Cache partition.
Jangolde
effective ba pag nag reset factory setting?
Jnoitab
I mean yung, Clear Cache Partition sir. need mo wipe out yun para sa mga cache reports error yan sir. Maybe its a bug. Nagkaganyan din phone ko last time, nirestart ko then ganun pa din, and last na ginawa ko clear cache partition sa factory reset nag okay naman.
Jnoitab
Cache lang naman ang mawawala doon sir hindi mismong files mo. Hehe
Jangolde
saan yan makikita?
Jnoitab
Plug in your usb connector to Laptop then shutdown your phone, press the volume up & power botton, after mag appear samsung logo, released the buttons na then locate nyo doon yung "Clear Cache wipe out"
Volume up and down buttons, select = power buttons. Then click mo lang reboot if okay na or mag automatic naman yan for sure mag reboot. Hehe
Jangolde
ok thanks try ko to mamaya
