Resolved! Solved
S21 ultra battery
(Topic created on: 10-19-2021 04:37 AM)
reveshawn
Hello every one! Can Someone help me regarding my battery issues with s21 ultra? I've been into service center for 2 times. 1st is moisture detected in the port and they just use a blower to fix it (August) 2nd battery drain issue they just reformat my device (September) Now which is october 19th 2021 I still experiencing battery drain issue with 2hrs - 3hrs SOT from 95% to 20% I'm not sure if this normal. I really love my s21 ultra but it gives me battery anxiety because it don't last me a day. Specially I'm using this as my daily phone and I already change the settings to make the battery long except the 120hz since I'm having fun using it. I'm really tired going to service center all over again and they just did nothing or change anything. Can some one please help me regarding this issue
Thankyou
SamsungRightCare
Hey there! How's your recent Galaxy experience? Have you resolved your concern yet?
Battery life depends very much on how the battery is used and different devices differ in battery life. The expected battery life for your model can be found in the device user manual. The following tips will show you how to get the best out of your battery in everyday usage and how to look after your battery.
1. Reduce display brightness level
High display brightness and long screen time-out setting will increase battery drain. One of the simplest ways to prolong your device battery life is to reduce the screen brightness, and here's how you can do it:
1) From the home screen > swipe down from the top to view the notification panel
2) Drag the brightness slider towards the left
3) At the same time, adjust the screen time-out setting > Tap the gear icon at the top > Select My Device tab > Select Display
4) Tap Screen timeout > Set your time-out preferences
Special Tip: Try setting your screen timeout to 30 seconds and display brightness to Auto.
2. Close, disable or uninstall unused Apps
Some apps may run background processes that deplete your battery. Once you’re ready to uninstall your unused apps, there are a few ways to go about it.
The fastest way to uninstall apps:
 1) On your home screen > long-press on the app
2) Tap the Uninstall icon > Followed by OK
For more control over your apps:
1) Go to Settings > Apps.
2) Tap the overflow icon on the top right to sort apps by size or required permissions.
3) To uninstall, simply tap on the app name followed by the Uninstall icon.
Disable apps to increase battery life:
Unfortunately, some apps cannot be uninstalled on certain Galaxy devices like Samsung Galaxy S9/S9+. However, you can disable the apps to increase battery life. To disable apps, simply follow either of the paths above and select Disable.
3. Turn off Always On Display (AOD) or set a schedule
Always On Display or AOD uses AMOLED displays to show you certain information when your screen is "off". It allows you to easily check basic information such as date and time without activating the display. Naturally, any activity that makes your screen turn on all the time will consume some power from your battery. You can choose to turn off AOD or set a time schedule for AOD to turn on/off.
To turn off AOD:
1) Go to Settings > Lock screen and security > Lock screen and Always On Display
2) Turn off AOD by tapping on the AOD slider (circle will move to the left)
To set a time schedule on AOD:
2) Tap on Set schedule and follow the steps provided on your device
Special tip: If you're wearing a watch, set a schedule for AOD to display in the evening when you're home and watch-free.
4. Toggle off WiFi, Bluetooth, and GPS when not in use
Switch off Wi-Fi, Bluetooth, and GPS if you don't need them, as each regular check for a signal uses power.
You can switch each of these off by pulling down the notification panel (drop-down menu) and tapping the relevant icon.
5. Turn on Power saving mode
Power saving mode conserves battery power by limiting mobile device CPU performance, reducing screen brightness, turning off the touch key light, and vibration feedback. This model differs slightly between devices but generally, it will close all unnecessary apps and screens so that you can substantially increase your battery time. You can turn on Power saving mode manually, or you can set your device to go into Power saving mode automatically.
Go to Settings > Device maintenance > Battery
6. Download the latest device software
Check your latest device software by going to Settings > About phone.
Upgrade your software using either FOTA ('Firmware Over The Air', i.e. wirelessly) or via Samsung Smart Switch.
7. Check your device Signal bars
Check the number of bars that you normally see on your handset while at home or work. Using the handset in areas with very low signal uses a lot of power and should be avoided where possible.
8. Check how often your device synchronizes data
If like most people, you have a number of apps on your device such as email or social media, these apps will frequently sync, or check for new emails or updates. Frequently syncing can reduce your battery life. Check the sync settings on your apps or email, and ensure they only sync as often as you need them to.
9. Avoid fully discharging your battery
On much older types of batteries, the advice used to be to discharge them completely. However, completely discharging the battery on modern smartphones devices may reduce its life. It's best not to let your battery go under 20%.
10. Store your device properly
If you do not intend to use your device for some time and pack it away, ensure that it has at least 50% battery.  Minimize hot and cold exposure.
Extreme heat and cold can damage your battery.
For example, don't leave your smartphone in the glove compartment of your car on very hot or cold days. A common myth is that batteries last longer if they are put in the freezer. This is not correct and can damage your battery.
Hope to have helped you, and have your concern be resolved soon! Keep safe. 😀
46 Comments
butete
Sadly 120hz will eat up battery life
reveshawn
So you think the culprit is the 120hz?
butete
Yep
reveshawn
How bout yours? How long does it last?
butete
Im on s20 ultra 120hz drastically eats my battery but definite it will be same with s21 ultra
reveshawn
How long your s21 ultra last?
Magnaguard
Look up what apps eat away at your battery. It also depends on usage. Mobile data eats battery quickly too.
reveshawn
Here's my battery used for the last 7 days Screenshot_20211019-205554_Device care_2010.jpgScreenshot_20211019-205543_Device care_2008.jpgScreenshot_20211019-205604_Device care_2012.jpgScreenshot_20211019-205533_Device care_2006.jpg
reveshawn
Here's anotherScreenshot_20211019-205618_Device care_2014.jpgScreenshot_20211019-205652_Device care_2018.jpgScreenshot_20211019-205635_Device care_2016.jpg
