S25 Plus/Ultra 45W Charging Issue
(Topic created on: 02-25-2025 03:01 PM)
Garbotoxin
There seems to be an issue with the 45W charging for the S25 Plus and Ultra. When using the 5A cables and the Samsung Fast Charger (or any other 45W charger), the phone will keep connecting/disconnecting from the charging.
Will there be a fix for this?
7 Comments
Have you experienced this, or repeating what has been posted online?
Either way, Samsung Italy was the first to acknowledge this and advised a fix will come in the next update.
Not sure if they mean this update rolling out globally now, or the next one.
Having said that, I have not experienced this bug with my Samsung 45w charger and 5A cable.
If you are experiencing this, please use the 3A cable that came with the phone.
Samsung has added new charging tweaks to the S25 series to enable 15V x 3A charging, and the supplied 3A cable will give you Super Fast Charging 2.0
Garbotoxin
thanks, hopefully there should be a firmware fix soon. I got the Feb update today (Australia) but it doesn't look like it fixed this charging problem
Try the cable that came with the phone.
a4afeef
Can you confirm if the issue is still there?
Garbotoxin
I haven't run down my battery enough again to charge my phone, will let you know when I do.
I did see that people were not having any issues with the 3A cable that came with the phone. Just doesn't make sense that the 5A cable won't work lol
But that's the thing, I haven't faced this issue with my Samsung 45W charger and the included 5A cable.
It's really odd 🤷
Sammyemy
Same issue here, tried both 5a and 3a cable(not working). Found the final solution is to turn off and back on fast wired charging in setting manually. repeating this is really annoying every time I charge. PLZ FIX ASAP, Cheers.🙏
