Buds pro sound
(Topic created on: 05-18-2021 03:22 PM)
Deak79
Wearables
My buds pro sound great in ANC but sound terrible in ambient sound or off. Does anyone.else have this issue?
4 Comments
SamsungJon
Wearables
Hi @Deak79, can you describe the sound quality when ambient sound is on (i.e. echoing, static, etc)?
You can adjust ambient sound to 4 levels to suit your preference. See here for how to do so: https://www.samsung.com/au/support/mobile-devices/using-ambient-sound-on-buds-pro/
Deak79
Wearables
The music is quite tinny and bassless. When I have ANC on it is really good sounding.
SamsungJon
Wearables
I would recommend also checking your sound settings. To do this, go into your Settings app > Sounds and vibration > Sound quality and effects > Equaliser or Adapt sound. This will allow you to adjust your sound to the best for your needs.
If you believe that this could be a fault with your Buds Pro, I would recommend sending and error report. To do this:
- Go to Galaxy Wearables app > click on the device desired on the side menu. Then tap Contact us > Error reports (in the Get help section).
- Fill in details and the frequency of the issue that you have with the wearable. Click send.
Let us know if this helps or if you have any further enquiries!
Deak79
Wearables
I have the Adaptive sound set to my age. The sound stage changes when ANC is not on.
