Battery and heat issues
(Topic created on: 03-11-2024 06:16 AM)
ReigningStill
Hi guys, I just got my S24 Ultra last week, and I'm having a hard time figuring out why the battery drains so fast and heats up easily. Is it normal for a newly purchased S24 Ultra phone to behave like this? Thanks for your responses. Have a good one 🥰
13 REPLIES 13
jaymonts
Maybe there's too many apps running in the background, i think. My s23 ultra does it too so i restrict some apps by putting them to sleep. It's in settings-device care-battery-background usage limits- turn on "put unused apps to sleep".
ReigningStill
Hello thanks for the response, actually i did all of those, but same old outcome, it doesnt have a simcard in it im just finishing transfering my files from my iphone, im really excited for this new phone but now i felt like i was robbed for thousands of pesos 😮💨
jaymonts
S24 series is pretty much new atm. But it'll get better with software updates.
ReigningStill
@Micky_24 hope so ☺️ thank you i appreciate ur responses, i just thought s24 series ang good at battery life 🫣
I think its still learning your usage patterns, check device care.
ReigningStill
😅 thanks for the advise tho but how can i enjoy it if i cant maximize the usage of the device because of the batt issues hehe Anyways thanks for ur response i really appreciate it 😊
ReigningStill
Oh i see great thank you 😊
You just buy a new unit so that is still optimizing based on your usage. Give your phone at least a week or two and see the difference. Dont be paranoid, just enjoy your new s24u just like I do. 😎
ReigningStill
