12-23-2024 06:06 AM in
Galaxy S- Mark as New
12-23-2024 06:08 AM in
12-23-2024 06:29 AM in
Galaxy SHi jipid,
It looks like the "Speech Recognition and Synthesis" feature is consuming a lot of battery in the background. To reduce battery drain:
Disable Speech Services:
- Go to Settings > Apps.
- Search for Speech Services by Google or any related apps.
- Select the app and click Disable.
Turn Off Voice Recognition:
- Open Settings > Google > Settings for Google apps > Search, Assistant, & Voice.
- Tap Voice > "Hey Google" Detection.
- Turn off Hey Google.
Restrict Background Activity:
- Go to Settings > Apps > Speech Services.
- Tap Battery and select Restricted to stop the app from running in the background.
Check Permissions:
- Remove microphone and background activity permissions if not required.
After making these changes, monitor your battery performance to see if it improves.
Thank you.
10-17-2025 12:13 PM in
Galaxy SSame thing happened to me when I update from UI6.0 to UI 7.0 and then again with UI 8.0 this week. Drain 70% battery in 4 hour when my s24 ultra used to last 2 days.
This apps is build in, you cannot unistall it, when you do in the playstore, it keep showing "update". At least it solve the problem but not more ok google and vocal command.
This is only a 2000$ phone, not good enough to have vocal recongition, wowww.
