Camera issue and quality (Nougat)
(Topic created on: 03-31-2017 11:03 PM)
kit71717
Nick
Please work on the camera app.
I use my s7 edge camera daily for work and the picture quality dropped by a lot in Nougat compared to MM. I mean, I thought updates are suppose to make the phone perform slightly better, but apparently, not for Nougat...
1 REPLY 1
Hey @kit71717, there should be little to no noticeable difference in camera quality after the update. Make sure your camera settings are set to maximum resolution, and try cleaning the camera lens of fingerprints. You can also try "Pro-mode" to adjust some of the settings manually.
