Device won't lock
(Topic created on: 03-22-2017 06:54 AM)
iShak
after updating, my device doesn't ask for a password even when I have pin & fingerprints enabled, please help!
6 REPLIES 6
musmus24
delete it and set it up again
iShak
ok
iShak
nope, still same problem
Titan1
Are you using Smart Lock?
iShak
yes but I'm not in the location that smart lock is supposed to work
Hey @iShak make sure Settings > Lockscreen and Security > Secure Lock > Lock instantly with power key is ENABLED. Also disable Smart Lock from the same screen, as your location may not be accurate.
