Edge Panel crashing hard and Battery drain.
(Topic created on: 04-05-2018 06:37 AM)
s25curator
Edge panel stopping every 15 mins. screenshot added. please solve this ASAP as I'm also noticing other significant battery related problems on s8. In the first 1 hour I loose around 15% of my battery with nothing running in background. This all started happening after April 1st security update for s8fbe291d7-16f3-434c-b62c-ec539ba0a35d.jpg
6 REPLIES 6
Did you Factory Reset your phone after the update? Or at least Boot into Recovery and Wipe Cache? d4abf59a-d555-4a91-82b0-7e6b61bad916.jpg
s25curator
nope. do i have to?
Are you using any Themes? If so so uninstall them and see if you still get Edge Screen FCs - If you're still having issues with apps crashing & poor battery life - than if it was my phone I'd definitely start with Wiping Cache in Recovery and if I still had issues then I'd backup my apps and settings to Smart Switch and Factory Reset 😉 🐧
s25curator
how do you do that?
Moderator_
Hey @s8curator, if your problem does not get resolved with what @ShaggyskunkS8P suggested, please submit a device error log when this happens again? From the Samsung Members application, tap the “Feedback” icon. Tap the Pen icon and then submit an “Error report”. Thanks!
- Wonchul
@s8curator - You mean How do you Boot into Recovery etc?
Power Off your device:
Press & Hold Power + Bixby + Volume UP
Wait until you get to the Stock Recovery Menu and make the selection you want to execute - Then Reboot. If you Selected Factory Reset your phone will be as it was when you first received it as new - Setup your phone and see if the issues are fixed.
If you only Wiped Cache - See if the issues are fixed.
In both cases give the problem some time to determine if the battery life & performance has improved 🐧
