02-27-2022 06:59 PM in
Galaxy SSolved! Go to Solution.
03-24-2022 09:27 AM in
Galaxy SHi Nigie, as the issue continues, we suggest submitting logs as an error report. Our team will be able to analyse diagnostic data and will be able to advise on how to best proceed with the issue.
How to raise an error report:
Launch Samsung Members > Get Help > Error reports > select issue category > describe issue and frequency > Tick ‘send system log data’ > Send in top right.
02-28-2022 01:51 AM in
Galaxy SYes, i'm having the same issue with the S22 plus. The battery has been draing extremely fast!
02-28-2022 06:44 AM in
Galaxy S- Mark as New
02-28-2022 12:29 PM in
04-14-2022 11:47 PM in
Galaxy SI have the draining issue on my new phone but didn't have it on my over 2 years old note 10plus... wierd. I use the phone I. The same manner so it has to be the phone...
02-28-2022 05:49 PM in
Galaxy SHi @Sammyaus, I am sorry to hear you're having issues with your new phone.
Do you multitask with your device such as calling whilst browsing or charging your device whilst using it? These processes take up CPU in the device and can cause the device to increase battery consumption.
First thing you should do is stop any apps that might be running in the background [recent applications (left navigation key/icon)>close all].
It is also a good idea to use device maintenance to optimize the phones settings [settings > device care >optimize now > done > battery/performance mode > storage > memory > device security].
As battery drainage can be due to active apps using the data connection (mobile data or Wi-Fi), you can also turn on data saver in the phones settings [settings > connections > data usage > data saver > toggle: on] and you can also allow unrestricted data usage for particular apps in this menu.
If the issue persists, I suggest sending an error report via the Samsung Members app for this to be investigated. Error reports are sent to our team to identify any deviations in your device performance, once analysed, our team will get back to you with a response to advise further.
To send an error report:
Samsung Members > Get help > Error reports > select issue category > describe issue and frequency > Tick ‘send system log data’ > Send in top right.
02-28-2022 06:17 PM in
03-04-2022 11:43 PM in
03-07-2022 03:38 PM in
Galaxy SHi there, you can view this in Settings > Device care > Battery > Since last full charge / Last 7 days.
06-21-2022 08:52 PM in
Galaxy SDear Laura
Iam using s22 ultra as phone call only
No 5g no 120 hrtz even airplane and display off
It's drain, draiiiin
