Group Emails Problem
(Topic created on: 04-03-2018 08:24 AM)
Shalleen
Beginner Level 3
When sending a group email, if I type the name into the "to:" field, and select the group as a recipient, it the S8 indicates 39 recipients, but only sends the email to about half the people in the group.
The workaround has been to select the contacts icon, then groups, and select the group from the list; this will ensure all members receive the email. The problem is, the groups take forever to load, and they are all listed in an expanded format, so I have to scroll through the "my contacts" group, which is every contact in my phone!!??
Anyone have a solution to this annoyance?
Moderator_
Hey @Shalleen, if you are using Samsung default email application, could you please contact (b2b.sec@samsung.com) for this issue? Thanks!
- Wonchul
