HELP FOR S7 MESSAGE FORMAT
(Topic created on: 06-02-2017 04:01 PM)
HeLPForS7
Hey..this is hard to explain but ill try..I just got this phone and love it...but the only Issue is the msg format Is not what I like...When I send a msg it kinda of stacks together instead of under the other parties reply...so in a conversation all I see is all my msgs together and theres together...I can never tell where we lefted off in a convo...how do I switch that?
2 REPLIES 2
A11
Unfortunately there's no setting like that, would have been good, but there's another way I do is when you go to Contacts​ and select any one from your contacts you will have 3 options call, message and Details. when you select message you will see all the conversation with that person with dates and time. Hope this will help you.
lacers
actually... if you reset your date and time to 'automatic' your conversations should then be in proper order
