How to open Bixpy Vision using Bixpy voice
(Topic created on: 12-29-2018 12:16 PM)
QuantumJash
When I tell Bixby Voice to open Bixby vision it says "looks like that's not an option in the context". is there any way to fix this and open Bixby Vision using Bixby voice?
4 REPLIES 4
I don't use it - But saying "open Bixby Vision" opens this 🐧
What device & Did you setup Bixby Voice? f76ece88-5a32-4461-9d3f-4ff1df1b262c.jpg
QuantumJash
I just bought Samsung S9 Plus yesterday. I used to be an iPhone user. I did set up Bixby voice and Bixby Vision.
Moderator_
Hi @QuantumJash,
This issue is difficult to diagnose or troubleshoot without physically inspecting your device. I would make sure that the setup is dont correctly, you can use https://www.samsung.com/us/support/answer/ANS00076739/ for instructions on the process. If the issue persists please contact your local Samsung Service Center (http://www.samsung.com/ca/support/servicelocation/) and they will be able to test and quickly find the issue. Thanks!
Wellant
When bixby is going to be in French.
