I wonder what's going on with my s23 ultra
(Topic created on: 09-19-2024 12:06 PM)
pirattemobille
I set the vibration so it vibrates on notifications & phone calls.
But the rest is off including system vibration, but the blasted thing keeps vibrating when i open & close the phone or web pages or open & close apps. It wasn't doing this two days ago. What is going on ?.
7 Comments
Helenna
Hi pirattemobille,
Please check the below settings once again. It sounds like there might be a system setting or app that has re-enabled on your phone.
Go to Settings > Sounds and vibration > System vibration and make sure all unnecessary options are turned off.
Disable Vibration for Certain Apps: Go to Settings > Apps > (Select App) > Notifications and turn off vibration for individual apps that may still have it enabled.
Reset Vibration Preferences: You can try resetting all vibration settings by going to Settings > General management > Reset > Reset accessibility settings.
If none of these work, you could try restarting your phone and see if it helps to solve the issue.
Thank you.
Been doing that since last night, there all off except for notifications & phone.
I even reset it. I find it odd. & The vibration for notifications is late it rings then 3 minutes later it vibrates.
I just installed nice catch to see what's going on.
Helenna
Hi pirattemobille,
If you haven't tried to perfrom Safe mode, please Boot into Safe Mode by holding the power button, then long-pressing Power off and tapping Safe mode. Test if the issue persists. if not, a third-party app could be causing the problem.
I will check it out
I found the issue thanks to nice catch.
NFC was trying to read my bus pass.
If ever tour looking for such a app it's available through the diagnostic page.
