qwer123
09-10-2024 11:03 PM in
There has been no discussion about this function, but it's time for it to be programmable. It's a rather redundant function and the palm swipe method of screen capture is redundant. To be honest, Smart Select is a much more practical feature and I would like it to be implemented. I would greatly appreciate if I could programmatically set my Power + Volume to a smart mode. It's quite laborious to remove my spen or access to the edge panels, which is why many individuals do not utilize it. However, if you could set it to a smart mode and allow more individuals to use it, it would be much more convenient. Without the ability to set it to a smart mode, you would be limited to sharing and by default, it would not save to the gallery, allowing you to have the option. I now understand that there is an option, however, I prefer Smart Select. It's a redundant feature and I rarely use screenshots and instead use Smart Select. This is because I don't want to constantly take a full screenshot and usually only save partial ones to my gallery. Smart Select by default does this. It makes sense to program the Power button + volume down to Smart Select. The entire purpose of screenshoting is to share and not to promote your gallery. This should be the default, however, it could be programmable and even the power and volume up buttons could be programmable. Furthermore, we could allow us to open certain apps.
1 REPLY 1
09-11-2024 05:40 AM in
Galaxy SHi qwer123,
We appreciate you for sharing your detailed thoughts and suggestions with us here in the Community.
We will certainly communicate this to the appropriate team for review and hopefully it will be affected in the future.
Thank you.
