Phone does a flash on screen and glitches out when clicking on screen
(Topic created on: 12-29-2021 10:19 AM)
rhyatt
Beginner Level 3
I did about ten updates in the last 2 days.  Now my  phone screen glitches out, with a quick flash while typing and key board resets.  Also happened while just using apps and clicking on screen.
 You tube won't stay in full screen, always goes to pic in pic mode after 5 mins.
Anyone else having issues like this?
3 Comments
Valeriya
Hi rhyatt, I suggest you please reboot your device in safe mode and check if you are experiencing the issue.
If you are not experiencing any issues in safe mode, then the issue could be due to any third-party application you installed recently.
To do this, you need to completely power off the device.
Then, power on the device, and when the Samsung logo appears, press and hold down the Volume Down key.
If done correctly, "Safe Mode" will display on the bottom left corner of the screen.
rhyatt
Beginner Level 3
It wasn't happening in safe mode.
I haven't downloaded any apps in months.
I did however delete all apps I don't use or anything I thought could be a issue.
It did glitch out there once I think but it happens so fast not a 100% sure it did lol.
Valeriya
Hi rhyatt, I suggest you to refer the below link and try the suggestions provided by RedDogRabbit.
https://r1.community.samsung.com/t5/galaxy-s/galaxy-s10-issues-messages-disappear-as-i-am-typing-the...
