S21 Ultra Battery Problems
(Topic created on: 12-01-2022 06:33 AM)
JoshRiando
Hey! Starting from when I got the phone I always got only around 3-4 hrs of SOT and thats with charging the phone every night and every middle of the day.
 The battery drains really fast but I only scroll through socmeds and play music on it. No gaming and other heavy tasks ://
7 REPLIES 7
Adriel92
Somethings running on the background that you dont see or maybe its an software issue.. One ui 4.1 literally have that issue including heating. Try updating ur phone to one ui 5.0
JoshRiando
Is there any way to check if a background or system app is ruining the battery? I have it on one ui 5.0 and I really thought it was gonna fix it
Adriel92
Did you check it on the developer options running services or in the device care battery usage
Actually when I was using the Galaxy S21 Ultra back in 2021, I also encountered this.
The most prominent cause is the refresh rate and the display resolution, if both are maxed out it'll really cripple the battery.
So most of the time, the refresh rate of my screen, along with the resolution is set to standard - for social media and binge watching.
I would bump them up once I start gaming.
JoshRiando
Really can't have it all I guess 😅. I'll try setting the reso back to 1080p and see if it helps. I just can't go back to 60hz my eyes will burn haha. Thank youu!
I know what you mean, but really it is just a matter of knowing when to utilize the features or, just live with it and just plug it in when needed.
TeamGalaxyRene
Hello JoshRiando,
Thanks for letting us know here, about your experience using your Samsung Galaxy S21 Ultra, having issues with battery draining faster in normal usage and apologize for the inconvenience it caused you.
You can submit an error report through Samsung Members app as follows:
Step 1. Long press Samsung Members icon on Apps screen and tap Error reports.
Step 2. Tap OK on agreement popup to send system log data.
Step 3. Select Symptom category "Power/Battery/Charging".
Step 4. Describe the problem in details and SEND.
How to submit an error report on Samsung Members app? | Samsung PH
Battery Optimization Tips, you may click the link below.
https://www.samsung.com/ph/support/galaxy-battery/optimization/
For more assistance, you may contact us on our online Samsung support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
Or contact our Samsung direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
84222111 [All Product, Landline]
Daily (8:00am to 8:00pm)
If the problem persists, immediately bring your device to nearest Samsung Authorized Service Center.
https://www.samsung.com/ph/support/service-center/
Hope this content is helpful and your problem gets solved.
