Resolved! Solved
S22 Battery Issues
(Topic created on: 11-13-2022 03:51 AM)
LeiS22
Kakabili ko lang po ng S22 phone. Naka optimize/ restricted/ deep slep/ data saver/ power saving/ adaptive battery/ adaptive power saving/ set into 60 Hz screen refresh rate at naka 85% protect battery na lahat lahat pero 8hrs lang screen on time naka 3x-4x akong charge, ganito ba talaga battery nito mabilis ma drain? Tapos within 10 mins 3%-5% agad nababawas sa battery kahit di ko ginagamit 🙄
I've used most of the battery hacks already but still functions the same.
Resolved!
14 REPLIES 14
LeiS22
I see. Ika-one week nia palang today na nagagamit. And lagi ko kinoclose un apps pag di na ginagamit lahat ng apps ko naka sleep at deep sleeping apps. Kaya i dont think may app na open at kino consume un battery ko. Ilang beses po kayo nagcharge using ur S22 Ultra?
dulber
Kundi sya gamit once lang. Kung may gaming CoDm more than 15mins. Twice at naka high settings ako sa lahat.
TeamGalaxyRene
Thank you LeiS22,
Sorry for that, your Samsung Galaxy S22 is experiencing a battery draining issue and we really understand what you are going through, trying several do-it-yourself battery optimization but to no avail.
But don't you worry, we are here to help, guide, quick fixes and offer solutions to your device's problems.
A) Ensure that your device is up-to-date with the latest Software updates.
Settings > About Phone > Software Updates > Download and Install > Follow On-screen Notifications.
Also, check Samsung members apps, notification bell icon for any updates information available for your device.
B) Check the Mobile Network Service Provider.
If the signal is weak, the phone will keep on searching for reception which is also one of the reasons why the battery drains faster. This is a normal response to the phone if you are located in a low to no-service location.
You may put your Samsung Galaxy S22 on Flight Mode if your location wherein there is no or weak signal as this ceases the attempt of the device to continuously find a reception, otherwise, they can get in contact with their network provider to get help on reception issues.
C) Battery Life and Performance Optimization.
Battery life can be affected by various factors such as device settings, environment and usage patterns.
Understand these factors to use your battery more efficiently and for a longer period of time.
https://www.samsung.com/ph/support/galaxy-battery/optimization/
D) Other Battery Conservation Tips.
  • Turning off Bluetooth when not in use is advisable as it drains the battery in the background.
  • Live wallpaper and screensavers use the battery a lot. So disabling or not using one may help the device to run smoothly.
  • If you have any widgets running that you don’t really need, consider disabling them.
  • The always-on display feature comes at the cost of battery life. So disabling it might be helpful to save battery power.
E) For more assistance, you may contact us on our online Samsung support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
F) Or contact our Samsung direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 22 111 [All Product, Landline]
Daily (8:00 AM to 8:00 PM)
Hope this content is helpful and your device's battery draining issue gets solved.
Make sure to click the ACCEPT AS SOLUTION button in your subsequent response, if we have satisfied your inquiry.
Tobsky
Sa akin din pag full charge after 5 minutes yata bawas na ng 1% ang battery ko.
LeiS22
Dibaaa!! S22 din po ba un phone nio?
