Resolved! Solved
S22 Battery Issues
(Topic created on: 11-13-2022 03:51 AM)
LeiS22
Kakabili ko lang po ng S22 phone. Naka optimize/ restricted/ deep slep/ data saver/ power saving/ adaptive battery/ adaptive power saving/ set into 60 Hz screen refresh rate at naka 85% protect battery na lahat lahat pero 8hrs lang screen on time naka 3x-4x akong charge, ganito ba talaga battery nito mabilis ma drain? Tapos within 10 mins 3%-5% agad nababawas sa battery kahit di ko ginagamit 🙄
I've used most of the battery hacks already but still functions the same.
TeamGalaxyRene
Thank you LeiS22,
Sorry for that, your Samsung Galaxy S22 is experiencing a battery draining issue and we really understand what you are going through, trying several do-it-yourself battery optimization but to no avail.
But don't you worry, we are here to help, guide, quick fixes and offer solutions to your device's problems.
A) Ensure that your device is up-to-date with the latest Software updates.
Settings > About Phone > Software Updates > Download and Install > Follow On-screen Notifications.
Also, check Samsung members apps, notification bell icon for any updates information available for your device.
B) Check the Mobile Network Service Provider.
If the signal is weak, the phone will keep on searching for reception which is also one of the reasons why the battery drains faster. This is a normal response to the phone if you are located in a low to no-service location.
You may put your Samsung Galaxy S22 on Flight Mode if your location wherein there is no or weak signal as this ceases the attempt of the device to continuously find a reception, otherwise, they can get in contact with their network provider to get help on reception issues.
C) Battery Life and Performance Optimization.
Battery life can be affected by various factors such as device settings, environment and usage patterns.
Understand these factors to use your battery more efficiently and for a longer period of time.
https://www.samsung.com/ph/support/galaxy-battery/optimization/
D) Other Battery Conservation Tips.
  • Turning off Bluetooth when not in use is advisable as it drains the battery in the background.
  • Live wallpaper and screensavers use the battery a lot. So disabling or not using one may help the device to run smoothly.
  • If you have any widgets running that you don’t really need, consider disabling them.
  • The always-on display feature comes at the cost of battery life. So disabling it might be helpful to save battery power.
E) For more assistance, you may contact us on our online Samsung support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
F) Or contact our Samsung direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 22 111 [All Product, Landline]
Daily (8:00 AM to 8:00 PM)
Hope this content is helpful and your device's battery draining issue gets solved.
Make sure to click the ACCEPT AS SOLUTION button in your subsequent response, if we have satisfied your inquiry.
14 REPLIES 14
EllisKai
Hindi ako naka S22..
Pero palagay ko, ganyan yata talaga ang samsung phones.
Ung kasama ko dati (matagal na, S4 pa yata), nacoconscious siya sa battery drain ng phone kaya mula nun, nag iPhone na siya.
Hindi ko na lang pinapansin ang battery drain kahit hanggang makabili na ako ng ibang Samsung S, then Note (10hrs daw tumatagal ang battery from full, according sa device care).
Hanggang isang araw, nakatulog ako ng matagal mga 6 hours siguro or 7 ganun, naalarm lang ako na nasa mga 46% na lang ang battery from 90% bago ako matulog..
ayun, nag deep sleep and sleep na q ng apps, nag battery saving, data saving (always on pa rin ang mobile data for automations and location-based reminders etc), extra dim. Naging around 13hrs na daw ang itatagal from full charge sabi sa device care.
Halos same lang sa pakiramdam ko, around 2 hrs pag minimal use, halos nasa pocket lang, konting messenger, browser, calendar, reminders gaun, mga 15 to 20% nababawas. Walang active social media usage (logged out).
Recharging pa rin every meal time, before going out, before bed kahit hindi low batt. Hindi ako nagcclear ng recent apps. Hindi ko ginagamit ang battery protect, maiinis lang ako sa battery life aha.. nagkakaroon din ng random restarts ang phone ko pag nag battery protect.Screenshot_20221113_215207_1000009676_1668347528.jpgScreenshot_20221113_212424_1000009670_1668345864.jpgScreenshot_20221113_212515_1000009672_1668345915.jpgScreenshot_20221113_212619_1000009674_1668345979.jpg
EllisKai
naka tap to show always on display pa rin pala ako kahit naka power saving.. Screenshot_20221113_215506_1000009678_1668347706.jpgScreenshot_20221113_212231_1000009667_1668345751.jpg
EllisKai
pag nasa bahay, naka always show ang AOD..
tapos hindi na ako naka power saving..
gumamit ako ng Bixby routines para naiiba-iba ang settings pag nagpupunta ako sa iba't ibang lugar..
kuntento pa rin naman ako kahit hindi ganoon katagal ang battery life.
EllisKai
wag mo na lang siguro masyado pansinin ang battery life. at isakto mo ung charging pag meal time m, o naliligo, toothbrush etc aha..
o kaya, mag ibang brand k n lang. okay ung tagal ng battery life ng iPhone 13 Pro Max based sa mga reviews ah..
hindi kita pinaaalis sa Samsung brand ha..
Wala, maganda lang ung nababalitaan ko about iPhone batteries starting 13 Pro Max and it seems like ganyan lang talaga ang sa Samsung.
1 week used pa lang yung phone. It's still learning OP's usage pattern. Yung Note20U5G ko, almost 2 years na hindi naman ako nabibilis sa battery drain. Adaptive battery and limited notifications lang ang settings ko pero parang ok naman.SmartSelect_20221117_015241_Samsung Members_1000000551_1668621161.jpg
bnnppl
I'm s22 user also once a day lang ako mag charge but i charged my phone everyday, i left my phone all night and in the morning i saw 5% to 4% decreased battery.
dulber
Ganyan talaga kapag bagong bili at unang pag intindi sa battery life. Ituloy mo lang stilo ng pag gamit mo. Madidiskartehan mo din kung kelan ka mag charge.
LeiS22
So, u mean ganito talaga mga S series lalo na pag bago? Pag kumakaen nalang ako or pag may ginagawa mag charge. Pero ambilis talaga nia malobatt kahit di ginagamit laki nawawala agad.
dulber
Pag bago pa lang inaaral pa ng power AI yung usage mo. Eventually may improvement yan. Etong S22 Ultra na gamit ko inabot ng ilang adjustments palagay ko kse hindi ko agad na kalikot at bihira magamit. Adjust yung AI sa pattern ko everytime. Ang pinaka effective is use the device care app. Optimize then close all apps bago mo iwan. Natural na yung 5% use kapag idle. Kung 20% ibang usapin na at need hanapin kung may app na matakaw sa power
