Samssung s6 edge plus
(Topic created on: 02-15-2025 12:17 PM)
Edgeplus
Samsung s6 edge plus.
Disaster. During battery change, the terminal came off old battery and I didn't notice.
New one (no idea why!!) comes with partial charge. Many attempts to reseat it before I noticed.
Restarting phone goes into loop, stays on the single Samsung logo that flashes. Ran recovery and got " DM verify error..."
Tried everything including factory reset. Same error. Ran graphics test and got error.
I suspect somewhere along the line something shorted?
Any ideas, much appreciated...
2 REPLIES 2
raider1900
Helenna
Hi Edgeplus,
We are sorry to hear that you’ve run into quite a tough situation with your Samsung Galaxy S6 Edge Plus after the battery change. Since you mentioned that the terminal came off the old battery and you didn’t notice, it’s essential to check all the connections again:
Ensure the new battery is properly connected to the motherboard. Sometimes, a loose connection can cause booting problems.
Inspect for any signs of physical damage on the motherboard, especially around the battery terminals or power connectors. Look for any visible burnt areas or broken traces.
If you're still unable to get past the boot loop or the phone is still giving you errors, would suggest taking it to an authorized Samsung repair center to fix the issue.
https://www.samsung.com/ca/support/service-center/
Thank you.
