Galaxy4 and Fit both blackscreened within 3 days. What is going on???
(Topic created on: 08-01-2024 11:37 AM)
cynsun2001
Wearables
So I'm a big fan of the Galaxy wearables.  I've had a bunch.  My Galaxy4 has been my go to watch for about 2.5 years.  Last Saturday, it blackscreened, won't reset, won't charge.  I didn't do anything differently, it just failed.  After some research, it looks like it may have bricked.  So I dig out my older GalaxyFit - it's working fine.  Haven't worn it in awhile, so it needs to charge, resynch etc.  All is fine.  Yesterday, I check my watch it's at 79% and has been impressively holding its charge.  A short while later, I look at it - no display.  Only a black screen. 2nd watch bricked in a few days.
What is going on Samsung???  This reeks of a bad software update.  I called customer support and because my watch is out of warranty, I'm being told I'd have to pay for repairs.  What?  If Samsung is messing with software to get us to upgrade/ replace wearables, not only is that unethical and bad for the environment, it's also criminally culpable.  Has anyone else had any issues like this?  One watch - sure, 2 in a few days?  Clearly, this is a Samsung induced problem.
Looking for some guidance here, as this is not only frustrating but makes me reconsider being a samsung customer.
2 REPLIES 2
Helenna
Wearables
Hi cynsun2001,
We are very sorry to hear about the issues with the watches. Is this issue happened after the update? Have you tried charging them and still not turning on?
Tony_gwh
Wearables
It's probably done for. I had Samsung Gear Sport dead in 2.4 years and two GW Active 2 (40 and 44 mm) coming to "natural" end within 2-2.5 years. 44mm GW Wactive 2 showing same behaviour as your GW4. I aslo would assume new AI features will overload old platform. Given age of platform it cheaper to buy new on sale compared to fixing it. New watch everey 2 years! By design! I tried to fix GW Active 2 40mm, but it was apprised more than it was worth to buy it again so i droped idea to fix it. Fit was good. My worked for 4 years before strap broke it it quitley fell off somewhere. It was still wroking fine.
