PLS HELP MY SAMSUNG BUDS FE CHARGING CASE
(Topic created on: 01-29-2025 03:02 PM)
hcneypearll
Wearables
sooo i got this samsung buds fe right, and i know in the user manual, you shouldnt open the case when/while you were charging the case, but unfortunately, i accidently didnt close my buds case ... it was for like 1 minute tho,, but still in charging... AND THENNNNN WHEN I CHECK IT, the indicator lamp for charging or not DID NOT LIGHT UP LIKE THEY SHOULD BE. right now im panicking cause its not charging my buds also the case is not charging too when i plug it to the charge.. i saw someone lost the charging buds awhile ago and they say samsung actually sell the charging buds only.. but its still a bit expensive for me.. is there any way for me to do about this??
WhatsApp Image 2025-01-29 at 13.55.45.jpegWhatsApp Image 2025-01-29 at 13.55.46.jpeg
.. what should i do??
3 Comments
Ridwannajjar7
Wearables
you can see this on YouTube to solve charging problems on buds fe https://youtu.be/mjJGgI9ghec?si=v-CWXd6QkxINujJD
Wearables
It's definitely concerning when your earbuds and case aren't charging, especially after a small mishap. Don't panic just yet! While opening the case during charging isn't recommended, a minute is unlikely to cause permanent damage. Here's a troubleshooting plan:
1. The Basics (Often the Fix!):
* Cable and Adapter Check: Try a different USB-C cable and wall adapter. Sometimes the problem isn't the Buds FE, but the charging setup itself. Make sure the adapter is a reputable one and capable of providing enough power.
* Clean the Contacts: Gently clean the charging contacts on both the earbuds and inside the case. Use a dry, soft cloth or a cotton swab. Dust or debris can interfere with charging.
* Case Reset (If Possible): Some earbud cases have a reset procedure. Check your Samsung Buds FE manual (online or the one that came with the buds) to see if there's a specific reset method. This often involves holding a button for a certain amount of time.
* Buds Reset: Similarly, look in the manual for how to reset the earbuds themselves. This might be separate from the case reset.
2. Longer Charging Attempt:
* Leave it Plugged In: Even if the indicator light isn't coming on, try leaving the case plugged in for a longer period (a couple of hours). Sometimes, after a power drain or a minor glitch, it can take a while for the charging circuitry to "wake up." Don't keep checking it constantly; let it sit undisturbed.
3. Indicator Light Behavior:
* Understand the Lights: Carefully review what the indicator lights should be doing according to the manual. Sometimes a flashing light or a different color indicates a specific issue. The absence of light doesn't always mean complete failure.
4. Samsung Support is Your Friend:
* Contact Samsung Directly: If none of the above works, contact Samsung support. They might have specific troubleshooting steps or be able to determine if there's a hardware issue. Explain the situation calmly. Mentioning the accidental case opening is okay, but focus on the fact that they aren't charging.
* Warranty: Check if your Buds FE are still under warranty. If they are, this is the best route.
5. About Replacement Parts:
* Charging Case Only: You're right, Samsung sometimes sells replacement parts, including charging cases. However, this is usually more cost-effective than replacing the entire set. Check the Samsung website or contact support to see if the charging case is available for your model and its price.
Important Considerations:
* Don't try to open the case further or attempt any repairs yourself unless you're experienced with electronics. This could void your warranty.
* Be patient. Troubleshooting charging issues can sometimes take time.
I hope this helps! Start with the simple steps, and don't hesitate to contact Samsung if needed. Good luck!
Mogay
Wearables
forget it and buy a brand new buds
