Resolved! Solved
Stuck in Work mode
(Topic created on: 10-18-2023 07:26 AM)
lilJ01
Bixby
I added some apps to "restricted" during work mode then tried taking them off and then all the apps that werent restricted got restricted then I tried doing the opposite and long story short there are some essential apps I cannot open like chrome, gmail, internet, contacts, camera. I've tried deleting work mode, turning on/off and restarting what do I do now?
RedDogRabbit
Bixby
Try this:
  • Go to Settings > Apps Search for "Modes & Routines" > Click on it & Scroll down to "Storage" and Clear Both Cache & Data for Modes & Routines. Reboot.
5 Comments
RedDogRabbit
Bixby
Try this:
lilJ01
Bixby
I had to play around with it for this to work but I was able to! I had to go modes and routines > the 3 dots on the top right. settings/ about modes and routine/ the "i" on top right> then clear data and cache
RedDogRabbit
Bixby
Strange, that you had to do anything other, than Scroll down to it's Storage & Clear Cache & Data 🤔
 But good to hear that you've got it resolved 👍🏻
lilJ01
Bixby
Helenna
Bixby
Hi, that's really great to see that your issue is resolved.
Please contact us back if you need any further information.
Thank you RedDogRabbit.
