blocked private numbers, can not receive calls, need help to fix it
(Topic created on: 08-08-2018 06:11 PM)
juniormiss
Galaxy Note
cannot receive private number calls, sends it to voicemail
1 REPLY 1
Galaxy Note
Hi juniormiss, maybe you have block unknown callers enabled.
Open Phone > click 3 dots > Settings > Block Numbers > Take a look if block unknown callers enabled, if it is, disable it. Then you can receive private caller.
Note that block unknown caller also block private caller or no phone numbers.
