HELP: S Pen writing sound
(Topic created on: 03-22-2021 01:09 AM)
AVICI01
Galaxy Note
Hi friends, how do I turn on the writing sound of S-Pen when writing on Samsung Notes?
4 REPLIES 4
AVICI01
Galaxy Note
Update: I've found out why I didn't hear the S-Pen scribble/writing sound, it was because I had "Do Not Disturb" turned on which blocks, feedback sounds.
Halston
Galaxy Note
Hi AVICI01,
Glad to know that the issue is now resolved after turning off the DND Do Not Disturb Mode.
Below are few details about DND mode:
Please note that Do Not Disturb mode mutes all calls and alerts on your device unless you set them as exceptions. You can set the Do not disturb mode to turn on and off automatically at scheduled times.
Follow the below steps:
Navigate to Apps >> Settings >> Sounds and notifications >> Do not disturb >> Enable/Disable.
When you want to turn on Do not disturb mode to concentrate but are expecting an important call, You can allow exceptions and customize what alerts you receive.
Open the Quick settings panel by swiping down from the top of the screen. Touch and hold the Do not disturb icon to open up its settings. Tap Allow exceptions and then choose from the displayed options.
Can I mark your comment as a solution? since it will help others with the same query.
AVICI01
Galaxy Note
Hi thank you for your reply. Yes you sure can!
EthanWhite
Galaxy Note
Difficult situation, I agree. Basically yes, you can't do anything with your brother if you are both grown men. Contact this AssignCode.com to get write code for me and keep it locked so that your brother never steals it again. For the future, remember to change the password on your computer. This is not a public library!
