note 10 plus additional led notification lights
(Topic created on: 03-02-2020 08:08 AM)
CynicalJerk84
Galaxy Note
Stumbled across this gem after using the app arc lighting from the play store. After trying a few competitor apps. I found one that has led lights show up as messages across the front of the notification screen. It was fully customizable even multible color selection available.
I have since removed it. Sticking with arc lighting app. However i was completely unaware that the note 10 had a built in led to the left of the camera under the screen nor that it was a feature users could download third party apps and utilize. Well done Samsung.
9 REPLIES 9
CynicalJerk84
Galaxy Note
might have been this app. i liked how it was able to display txt led messages. hope this helps someone. i have a wallet case so i opted out of have the feature.
Galaxy Note
i bought this one because you said its good. hahaha.
CynicalJerk84
Galaxy Note
arc lighting is amazing can't seem to find the other one was very cool tho
CynicalJerk84
Galaxy Note
Vic20
Galaxy Note
CynicalJerk84
Galaxy Note
found the website and the app crazy customizable.
Jeremie
Galaxy Note
@lpo2020
The LED indicator you are referring to is the proximity sensor. However, you may use the edge lighting(In-built) feature to get a notification around edge panel of the screen.
CynicalJerk84
Galaxy Note
no it's definitely not the proximity one there is another i had it working. prox does not show txt
