Resolved! Solved
Separate sound issue.
(Topic created on: 08-27-2021 07:56 AM)
Teapot9318
Galaxy Note
Hi. I'm running a galaxy note 20. I am really liking it so far, my only issue I am having is my text message sound  is sounding the same to face book or snap chat. It all has the same sound. I have played around a little bit and only been able to change is the system sound. Any one help? Thanks in advance.
Valeriya
Galaxy Note
Hi, If you found a solution to your query please take the time to accept the comment that you find helpful as a solution by clicking on 3 dots and tap on "Accept as Solution" and help others with the same query.
3 REPLIES 3
Valeriya
Galaxy Note
Hi, Glad that you are enjoying your new device. To set a default alert for all messages, you will need to change your notification sound settings. Navigate to and open Settings, and then tap Sounds and vibration.
Tap Notification sound, and then select your desired alert tone.
When you are done, tap Back.
The tone you picked will play whenever you receive a message.
However, you can also set specific message tones for certain contacts if you would like.
Teapot9318
Galaxy Note
Thank you. I figured it out.
Valeriya
Galaxy Note
