03-14-2025 08:27 PM (Last edited 03-14-2025 08:28 PM ) in
Galaxy S- Mark as New
03-14-2025 08:52 PM in
03-14-2025 09:11 PM in
03-15-2025 03:11 PM in
03-17-2025 01:20 PM in
Galaxy SHi ˢᵒⁿᶦᵈᵉ.
Yes, that's correct! The OIS module in the camera has floating lens elements, which can move slightly when the phone is shaken. The slight movement inside is completely normal and is part of how OIS helps stabilize photos and videos. When the camera is in use, the mechanism locks into place. This is completely normal behavior for high-end Samsung devices with OIS.
Rest assured, your Galaxy S25+ is functioning as expected!
Thank you.
03-17-2025 03:27 PM in
Galaxy SI was only thinking, why would someone shake their phone hard enough for it to make noise in the first place, too risk dropping it
