Resolved! Solved
Battery degradation
(Topic created on: 11-03-2024 05:09 AM)
guitargod
Hey,
I've noticed over the past couple months my battery lasts quite less time than it did prior to a couple months ago..have I been using it a lot more? I'd say yes but not overly, is it possible for a battery to degrade over a period of a couple months??I'm using a galaxy s23 fe
Thanks
Brad
2 Solutions
JeanAbiN
Well you can try to turn on battery saver
RedDogRabbit
If there is any issue with the Battery, a battery saving mode won't address the problem, even if the battery lasts longer. You are giving up performance.
Start with opening the Samsung Members app and run the Diagnostics for the Battery.
If it's saying that it is "good", it could be more apps are running in the background. Put unused apps to "sleep".
Check that other apps are "Optimized".
Last things, if you haven't, Boot into Recovery & Wipe Cache.
If you are SURE that the Battery isn't lasting as long as before, you could always backup your device with Smart Switch & Factory Reset.
5 Comments
JeanAbiN
guitargod
Yes I've been doing that all along..and it still doesn't last..like when I turn it on but I only turn on the battery saver without turning off your homepage and limiting apps, it says it will last 15 to 20 hours as opposed to 30 hours like before.
RedDogRabbit
guitargod
Very good..yes thank you
Helenna
Hi guitargod,
We are good to see that you found the required information from RedDogRabbit and JeanAbiN and your issue has been resolved.
Please write back to us if you require any further assistance.
Thank you JeanAbiN and RedDogRabbit.
