Battery Drain Issue on S24
(Topic created on: 12-31-2024 10:56 PM)
MightyEagle35
Since the last software update, I've noticed my Galaxy S24’s battery drains significantly faster than before. I haven’t changed my usage patterns, so I’m wondering if this is a common issue. Has anyone else experienced this problem? If so, have you found any effective solutions or workarounds? I’ve tried some basic troubleshooting steps, but the issue persists.
What steps can I take to improve the battery life on my S24 after the latest update?
3 Comments
Moderator3
Hi, you can to go to the nearest SSC to check your device, and you also can use fitur Live Chat to get the details information. Thank you.
Mogay
the only way is wait another software update, that's the downside of new security patch update and it can bring battery drain issue in exchange for better security
updating your phone which mean you are ready to face any new problems added due to installation of new security patch update
KaptenBff
My S24 is very wasteful and also the temperature is very hot.
New in other phones the temperature is already 38/42°, I use the lowest brighness, use 60hz anyway and also not play games just use daily, do not know the cause because what, most likely indeed from yesterday's sofware update.
